Mesh refinement and element size
Hello everyone!
Here I am once again! This time I'm working on a new project and I'm finding it difficult to control the mesh and to get the data I want.
Here's the thing, this project is composed by slabs and walls, no beams, and only 2 columns. When I try to define the mesh I can't get it large enough and thin enough where I want. As you can see from the pictures below, I want to refine the slab on top of the 2 columns inserting 2 emmiters, but I don't need this refinement on the whole slab, which makes my model complicated to analyze and harder to process.
In pictures number 4 and 5 you can see how exagerated my mesh is (it's way too thin!), but when I apply method in picture 5 nothing seems to change...
I would be very thankful if anyone can help me with this!
Thanks in advance
http://imgur.com/a/gMXvD
http://imgur.com/a/EZziA
http://imgur.com/a/LRP0u
http://imgur.com/a/tnFoI
http://imgur.com/a/5DpKO
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may consider:
- creating smaller panels with smaller element sizes in the location you need denser meshes
- run mesh refinement for selected surface (mesh) elements
- play with the marked parameters after setting Delaunay and Kang method
Artur Kosakowski
