Member Type Definition window
Please can you tell me in this window the changes to span length or support width where in calculations are reflected? I made changes but did not figure out where in calculations or visuals are reflected.
thanks
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
When at support faces is marked reinforcement is not calculated along support width (beams 1 and 2 , support width 0.4 m and 1 m). When in axes is marked reinforcement is calculated for whole beam (beam 3).
Krzysztof Wasik
Hello @Krzysztof_Wasik
thanks for the reply, please let me know where in the program can I see this effect either in calculation or in pictures as you send
Regards
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Results can be checked
(1.) In the Required reinforcement table (from RC Members- required reinforcement LAYOUT)
(2) by activating reinforcement diagram fro Results >Diagrams for members.
Krzysztof Wasik
Thank you very much for this answer, it seems that this is a quick interesting method for calculations, and really it reflects the changes made in (code parameters), but what was annoying that I all the time used Design - provided reinforcement of RC elements where in beam gemoetry the code parameters for support width and span length are not affected accordingly?!, also please tell me how to plot reinforcement details according to your last answer.
Best Regards
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
There is no possibility to plot reinforcement from RC required reinforcement module. Only reinforcement areas are calculated and presented (table and diagram). Reinforcement plots are available in RC provided reinforcement module only.
Krzysztof Wasik
@Krzysztof_Wasik
Clear. Thanks a lot for your efforts and support.
