Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Member list is incorrect
3 REPLIES 3
561 Views, 3 Replies
Whenever I try to design my structure a message comes up with 'incorrect member list'. I have checked previous post's here about this issuse but I do not seem to have a material problem or bar type problem. I cannot even add members to member verification list. Please check the attached screencasts.
I have also attached the .rtd file.
3 REPLIES 3
Romanich
You have to fill marked fields:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
in reply to: Romanich
Actualy, that is the issue. I cannot add any member to the list, it just does not add anything.
Artur.Kosakowski
Is it possible that the member types you defined for bars of the model are for different code than the one you have got currently set in Job Preferences? If yes, try to set this code as the current instead. If not, try to generate the default Job Preferences
Artur Kosakowski
