Member Lateral and compression/tension stiffness
JPNR87
JPNR87
how does Robot calculate member stiffness
1. Compression/tenion stiffness AxE ?
2. Lateral stiffness IxE ?
Is it right?
"A" and "I" can be adjusted in member section properties and "E" in material properties
Thanks!
EduardoMeruvia
Hi @JPNR87 ,
That is correct. The member axial and bending stiffness is derived from its crossectional area and second moment of areas correspondingly. Which then acts in conjunction with the material young modulus 'E'.
