maximum permissible loading
Hello
Does robot structural analysis solve for maximum permissible loading.
for example if i have an HEA 200 beam of length 6 m can robot solve for the maximum point load it can support at the middle
regards
Artur.Kosakowski
Autodesk Support
Autodesk Support
You can run verification of such beam according to the selected design code and increase the force till the safety ratio is 1.0.
You may find the recording of the 3rd Robot webinar on steel design helpful. It is accessible from:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-structural-analysis-webinars/td...
Artur Kosakowski
Thank you
That is what I was doing , I thought there is an easier way
Another issue concerning lateral buckling
If I make analysis of simply supported beam with point load at the middle it
passes with lateral buckling unchecked but fails when checked
For such beams we should consider lateral buckling??
Best Regards
Rafacascudo
It depends on beam cross section and if the beam is restricted laterally ( by a slab, for example)or not
Rafael Medeiros
