Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Matrix is not positive definite
7 REPLIES 7
Message 1 of 8
4034 Views, 7 Replies
I have a frame with lateral and gravity loads.  I wish to run a P-delta analysis to account for second-order effects.  When I do so I get the error "Matrix is not positive definite".  To troubleshoot the issue, I have added a lateral restraint at the top of each frame.  This would negate 100% of the sway.  Robot gives me the same error.  To troubleshoot further, I due a simple static analysis with the lateral restraints and the members are only lightly stressed.  I do not understand how to get rid of the "Matrix is not positive definite" notice for P-delta analysis.
I am using RSA 2018 with the latest patch.  I've included the model with the lateral restraints at the top of each frame and the P-delta analysis turned on.
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
Hi @Anonymous
You cannot intersect truss bars as they have no out of their plane stiffness. Try to replace them with bars with releases.
Artur Kosakowski
Message 3 of 8
in reply to: Artur.Kosakowski
Thank you Artur,
Sorry, but I sent you the incorrect model.  The model I intended to send did not have tension only bars.  It did have compatible nodes.  As it turns out, it will not converge using a P-delta analysis unless the compatible nodes are deleted.  I'm sure that I've used compatible nodes with a P-delta analysis in previous versions of Robot.  Has this feature changed in the 2018 version?
Best regards,
Carl
Message 4 of 8
Rafacascudo
then send the correct "incorrect" model!!Smiley Wink
Rafael Medeiros
Message 5 of 8
Artur.Kosakowski
Hi @Anonymous
I'd say the definition of compatible nodes is such that some part o the model becomes unstable under the level of the applied load. It can be the same story - if you released all rotations in the 'middle' node rather than only these in the bracing plane ...
As @Rafacascudo wrote - we need to see the 'right' model.
Artur Kosakowski
Message 6 of 8
Good day,
Here is the model using compatible nodes.  I've been trying different options to get Robot to use P-Delta including tension only and axial releases on the bars.  All of which work in non P-delta analysis, but not using P-delta.
Best regards.
Message 7 of 8
Artur.Kosakowski
Hi @Anonymous
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 8 of 8
As follow-up to this, we have successfully modelled this frame using compatible nodes and tension only members when using a P-delta analysis.  We accomplished this by changing the method of solving the system of equations to "Multi-threaded solver" from "Automatic" under Tools -> Job Preferences -> Structure Analysis.
