Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
material error
5 REPLIES 5
1280 Views, 5 Replies
material error
i got a model where one of the bars are getting an error. its saying that "material is not defined for bar no 22". when im in the object inspector it has a material. whats wrong?
5 REPLIES 5
Artur.Kosakowski
Please open the bars table and switch to the Edit tab. Most likely the material assigned to bar 22 is N/A. Change it to the right one selected from the available list.
Artur Kosakowski
in reply to: Artur.Kosakowski
i have tried that, but it stil dosent work. i cant see what the problem is
Artur.Kosakowski
Send the rtd file please.
Artur Kosakowski
thank you
Artur.Kosakowski
In fact there is no material assigned to panels (or panel thickness label to be exact). Please define a new thickness (make sure you entered the right thickness and selected the right material) and apply it to the panels.
Artur Kosakowski
