Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Material database error
7 REPLIES 7
Message 1 of 8
Priitl220
1458 Views, 7 Replies
Database is corrupt or seomthing. Concrete , aluminum and timber are empty.
Changed reginal settings to somethign elsese, did restart ARSA, back to Eurocode restart. Niothing.
Cleared cfgusr. No help.
Unistalled and reinstalled.
What next?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
7 REPLIES 7
Message 2 of 8
Try to rename this folder:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\201x to e.g. C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\__201x
201x stands for your RSA version e.g. 2016.
Artur Kosakowski
Message 3 of 8
I had that problem once
http://forums.autodesk.com/t5/robot-structural-analysis/material-list-vanish/m-p/5704200#M35439
Rafael Medeiros
Message 4 of 8
in reply to: Priitl220
This problem is very common. It occurs to me when I open a file that use materials that are not in the data base. I want to change some parameters of the material, so I save the materials in data base with the option in the material tool and ....THE ERROR. What is the correct form to change parameters of materials hat are not in data base?
Message 5 of 8
Artur.Kosakowski
I hope you find thsi movie helpful:
Artur Kosakowski
Message 6 of 8
in reply to: Artur.Kosakowski
Well, I'll try to explain the point of my recent post. I received a model with materials created, I don't created this materials. When I reviewed the properties of materials I find a incorrect parameter, but I can't change it inmediately, because the material doesn't appear in job preferences, but it appears in materials tool, but i can't change parameters of the materials there. then, When I used the tool indicate in the picture, the error mentioned in the original post take place. For that reason I ask the question, Are there any method to change parameters of a meterial that I didn't create?
This happens when I import a model from revit too.
Message 7 of 8
Sorry for the language I used Robot in Spanish and I don't speak english very well.Smiley Frustrated
Message 8 of 8
Artur.Kosakowski
Yes, but that would require to create a one (with the same name) in Job Preferences > replacing the material originally defined in the model with another one > removing this material from the project > applying the (newly created) material from Job Preferences to the objects of a model. I think it would be much easier for you to just create a new material in Job Preferences with properties as you need them and replace the one from the model with this new one.
Artur Kosakowski
