Mass participation Rz
Message 1 of 14
I am working on a 3d model for an industrial building and when I run a modal analysis, mass participation for torsional mode, Rz, appears with very low values (less than 1%). I am using consistent mass matrix and X,Y & Z directions of masses are active.
Why could this occur?
Any tip concerning this matter would be helpful.
Regards.
Replies (13)
Message 2 of 14
Romanich
Hi @Anonymous ,
It's hard to say without the model.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 14
Simau
@Anonymous
Could you attach dynamic results table with Ux Uy mobilzed mass
M. Agayr
Message 4 of 14
risefire12
hello mr roman
i have the same problem in RSA i get 0% for cur.mass.rz  for all modes even though my model have torsional irregularities... plz if you can look at my model
Message 5 of 14
Simau
Hi @risefire12
Looking at Dynamic results Table, it seems that there is no torsion in your building
M. Agayr
Message 6 of 14
risefire12
thank you for your reply!
if you view the deflection for mode 1 in robot you will realize that it is a torsional mode...
in addition i did the same model in ETABS and almost same results in participation in X and Y (blue color) but in Rz you can see results in etabs (Red color) and the first mode is 53% in Rz (0,5388 green color )...
so there must be an explanation for that
Message 7 of 14
Simau
Hi @risefire12
I agree with you about Rz value.
In my side, i never use Rz for torsion verification, but only mass participation in X and Y direction.
So I did a test with a structure having an obvious twist and indeed the value of Rz is always close to zero.
Maybe the support team have explanation
M. Agayr
Message 8 of 14
risefire12
it is really weird that it doesnt give any real values for Rz...hope the dev team response quickly
Message 9 of 14
risefire12
Message 10 of 14
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @risefire12
Similar topic was discussed before on Robot Forum
Please refer to
https://forums.autodesk.com/t5/robot-structural-analysis-forum/torsional-mass-participation-rz/m-p/6...
and linked
https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-modal-analysis-torsional-mass-p...
Rz mass participation is calculated for individual nodes torsion rather than for whole building torsion effect. Whole building torsion effect is represented mainly as UX and UY nodal displacement/mass participation.
In case of simple frame you can expect significant RZ mass participation for the following normal mode.
Krzysztof Wasik
Message 11 of 14
risefire12
Hi @Krzysztof_Wasik
First of all thank you very much for you reply.
I saw the two links thank you again, but please can you explain more how the torsional effects is represented by Ux and Uy ?
Message 12 of 14
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @risefire12
You can decompose each node displacement into Ux and Uy component
Krzysztof Wasik
Message 13 of 14
risefire12
so in general the only way to get the Rz for the whole structure is by changing the calculation model to Rigid diaphragm (No Fe's) ?
Message 14 of 14
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @risefire12
This solution is proposed in previous forum threads.
Krzysztof Wasik
