Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Maps on panels: displaying only positive/negative values
2 REPLIES 2
Jummybear
677 Views, 2 Replies
Is it possible to display only positive/negative values on panel maps? I searched forum and get a simple solution with simple scale where I can display values in some limits. But there are only 3 colours (green, red, yellow). I want a bit more differential map, for example with displaying only positive values in division with 13 colours. Is it possible?
When I put zero in the field "user limits->min" and press normalize/apply - nothing happens. When I stick off some checkboxes with all negative values - nothing happens.
2 REPLIES 2
Jummybear
in reply to: Jummybear
Found solution by myself. You can save any type of colour diagram you want, but if you want to display it YOU MUST choose in window "scale type selection" user-defined. Then it works.
Rafal.Gaweda
Hi @Jummybear
Not only 🙂
See below
Rafal Gaweda
