Longitudinal stiffeners
Hi everyone,
I was wondering if you can add longitudinal stiffeners to a closed box cross section as seen in an attached pic. I suppose either by modeling the arch as a shell (any tips on that?- I've never modeled a shell structure before) or designing an entirely new profile (have not done that either)?
Any help and guidance would be greatly appreciated.
Rafacascudo
It depends on what you want to achieve. If it is detailed stress analysis of the plates, then go for the shell model. If you are intending a global analysis, internal forces, displacements then go for a bar model with custom cross section that you can create on the section module
Rafael Medeiros
Thank you for such a quick answer. For now I think I will go with a custom profile module but I will be later on doing a detailed analysis or the arch. I found a webinar episode (How to create and run code verification of user defined section) that is quite helpful for the first option, however I would appreciate if you could guide me on creating a shell model. Anything really, to grasp the idea on working with shell models.
Rafacascudo
Shell type structure in Robot is created using panels . Every plate/slab/wall you intend to create will be a panel object.
There are some ways to create a panel . My favorite is using nodes , bars , translate+drag  and panels dialog window. This method  doesn´t generate "snapping to the point" errors which are the main cause of mesh generation problems.
Better explained on the video below . Full box section with stiffners beam , shell model ,created in 10 min and without errors . Model attached
Rafael Medeiros
