Load to mass convertion (harmonic/modal analysis)
rauno.verbitskas233CE
Hi!
How can I make a case where there are both load and mass for modal/harmonic analyse.
If I make load to mass convertion there is only mass shown but I would like load with specific mass.
I have attached .png file with the way I would like.
Thank You,
Rauno
okapawal
Hi @rauno.verbitskas233CE
You may use Modal analysis taking into static forces.  To switch to this analysis type:
- define modal analysis case
- select the case
- click "Change analysis type" buton
- in the "Analysis type Change" dialog change the case to "Modal analysis taking into static forces"
- select static case from which the load is taken
See help description for this topic:
Modal analysis recognizing static forces - description and example
Waldemar Okapa
Software Quality Assurance & Testing Engineer
