Hello all, I have created a model in Robot v14, then I opened with Robot v15 and continue working on it. I have a static load = "Ex" that applies an acceleration "a" on added masses and objects. I have some super dead load converted into "global mass" in all direction. When I was using v14 this worked perfectly, the total reaction from Ex = a *(SW + SDL) and every time that I changed anything, the value got updated. However, since I started working with Robot v 15, the total reaction from Ex = a*SW. I have checked and in my loading table there is a record for 'masses' and 'objects'. I have tried everything, deleting all the load cases and starting again to no avail, I don't get the load converted to mass. I have tried the same in a test beam model and it works well there. Has anything similar happened to you? Is this a bug, is the file damaged somehow? Is there any way around it? The model is very complex, and I cannot start over from scratch. Thanks a lot, V.
