Load to mass conversion: mass and conversion directions
Message 1 of 8
Hi Rafa,
Can you explane for me clear about Mass Direction & Conversion Mass, I feel some confuse of them.
@Anonymous Artur Kosakowski edited the topic for better findability
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Conversion direction: it is to decide which load defined in a selected load case should be treated as masses. By default it is -Z which means that all vertical loads acting downwards (e.g. weight of some piece of equipment or machinery bolted to a floor) is treated as active mass for seismic analysis. If you set it as e.g. X+ you could convert wind load but I don't think you actually need this Smiley Wink
Mass direction: allowable direction of vibrations e.g. you may exclude vertical; vibrations (of floors) while analysis a multi-story building with rigid floor systems or horizontal ones for a single slab (footfall analysis).
Artur Kosakowski
Message 3 of 8
Thank you very much for your explanation, so how Mass Direction in Load to Mass Conversion tab relate to Active mass direction in Modal Analysis Parameter table ?
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
This is the same definition
In most of the situation you first decide which directions of the vibrations you want to consider defining the modal analysis and then you mark the same check boxes for the load to mass conversion unless you want to perform e.g.  some comparison tests and e.g. unmark Z or (X and Y) in the modal analysis (or create a new modal case with such settings) to see the difference with all 3 marked.
Artur Kosakowski
Message 5 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to check if you still need any additional clarification on the mass directions.
Artur Kosakowski
Message 6 of 8
In a multi story building, I perform a modal analysis. I am interested in only vertical vibrations in time historical results. Should I choose only active mass-z direction in modal analysis? When I chose it, Force-z of the nodes in time history analysis is all zeroes. I need help.
Message 7 of 8
structural.engineer79
Dear Artur
In ASCE code in Static analysis the vertical seismic force add to dead load. In this case is z direction disregard or no in mass direction for load to mass conversation
Message 8 of 8
AnthonyMcTigue
It is possible to use the load to mass conversion tool to calculate and display the centre of mass of a particular subset of loads on the structure?
