Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Load Pattern, again
13 REPLIES 13
Message 1 of 14
HoshangMustafa
624 Views, 13 Replies
Load Pattern, again
I walked through all threads discussing Special Loads> Load Pattern, but unfortunately with no success. How one can use Load Pattern without getting trouble with too much combinations message?
13 REPLIES 13
Message 2 of 14
42 views, no replies.
Message 3 of 14
Hi @Simau
What is Load Pattern in French language? So I can search for a solution in French forum.
Message 4 of 14
What do you mean by combinations message? Never got it.
Rafael Medeiros
Message 5 of 14
too large combination
Message 6 of 14
Simau
in reply to: HoshangMustafa
@HoshangMustafa
M. Agayr
Message 7 of 14
Simau
@HoshangMustafa
M. Agayr
Message 8 of 14
HoshangMustafa
in reply to: Simau
Hi @Simau
Should I encounter too large combination problem with a small structure like mine? Please find the attached file:
Message 9 of 14
Simau
@HoshangMustafa
Using Full Automatic Combinations i can generate combinations without any problem or warning
M. Agayr
Message 10 of 14
HoshangMustafa
in reply to: Simau
Hi @Simau
Why mine displays the message on 07-23-2022 11:43 PM? Can you post your model with combinations? I use ARSA 2019.
Message 11 of 14
Simau
@HoshangMustafa
Model attached, but release 2022
M. Agayr
Message 12 of 14
HoshangMustafa
in reply to: Simau
Hi @Simau
Can you save it in 2019 release? It can't be opened with mine.
Message 13 of 14
Simau
@HoshangMustafa
It's not possible to save a model to an earlier release
For info, i didn't do any change to your model.
Could you attach some screenshots showing how you create your automatic combinations?
M. Agayr
Message 14 of 14
Romanich
Hi @HoshangMustafa ,
https://forums.autodesk.com/t5/robot-structural-analysis-forum/downgrade-to-older-robot-version/m-p/...
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
