Load issue in Nonlinear analysis
Dear,
I have problem with assembling selfweight to another load case automatically when performing non-linear analysis.
Why the software does that? This cousing me a problem in reactions report report because I have added selfweight in different load case.
Please help
Regards
Ivan Matoric
Rafal.Gaweda
Autodesk Support
Autodesk Support
I guess you have cables in model.
It is correct - assembling load case is case 1
Rafal Gaweda
Hi Rafal,
yes I have cables in the model.
Why that chage the situation I mean is that something that is normal for the Robot to do when I use cable elements.
If it is how I could avoid that? Should I use only tension member elements insted of cable elemens?
Ivan
Rafal.Gaweda
Autodesk Support
Autodesk Support
http://help.autodesk.com/view/RSAPRO/2016/ENU/?guid=GUID-C718E208-2359-49A0-9C8E-FAB4EA496948
Can be.
Rafal Gaweda
