Message 1 of 9
08:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hallo...i want your opinion about an issue... In the following picture you can see load distribution areas from slab-diaphragm to beams...but according to the theory the load distribution from a slab depends on the connexion with the other slabs...the angle is different in any case of connexion (pinned-fixed, fixed-fixed) as you can see in the picture...Robot takes the angle 45 degrees for every case...for exaple according to the theory there are 3 kinds of angle 45 (fixed-fixed), 60 and 30...
What do you think? thanks a lot...
