1 ) how Linking Robot Structural to Tekla Structures and vice versa ?
2 ) If I Export entire structure designed from Robot to Tekla, can I see entire structure Even with correct Steel Connections ?
send to me plz.
linking tekla structures to sap2000 & tekla structures to etabs linker
sap2000@outlook.com
Good day!
Please download link for me to communicate tekla-robot: https://warehouse.tekla.com/#/catalog/details/u0f2b9398-5a01-4c83-87c1-d778a63610d4
Thank you.
Sincerely, Nairi
my email: sargsyan.nairi@gmail.com
Vote please, for the good and important idea 🙂
Good afternoon, StefanoPasquini6790. Thanks for the advice.
The idea is interesting, but unfortunately for me it is the additional difficulty.
I want to establish two-way direct communication between Tekla-Robot.
I hope somebody will share all the same the last link
Good afternoon, mpcloob.
Please send mail: sargsyan.nairi@yahoo.com
Thank you very much.
p.s. I want to linking Tekla 21 - Robot 2016
I am trying to export a tekla 3D model into Robot 3D environment, can you please tell me how to do that? Thank you ^^
Teddy
My yahoo e-mail adress is: teodor.daskalov@yahoo.com
Thank you! 🙂
P.S.: what is this tekla-robot link? what does it do? is it some software that I have to use?
TeDo Tekla-robot link is a link that allows you to transfer-export your model created with Tekla ( Tekla ) to Robot structural analysis.
I don't really know if exporting a model created with Robot to Tekla is possible.
I'm also interested about this link but I do not have a yahoo mail. Please let me know if someone could send it to me (I have a gmail mail).
Does it work also with RSA 2016?
hello
every body can download links from these links:
http://s000.tinyupload.com/index.php?file_id=00258013467943292699
http://s000.tinyupload.com/index.php?file_id=01415031939945704592
http://s000.tinyupload.com/index.php?file_id=43733267386107040625
thanks.
Thank you very much for the files, but they are for Robot-Tekla link, right? Is there a way for me to export my TEKLA model into ROBOT?
BR
Tekla has a programme to convert Robot models to Tekla models and vice versa. That program doesn't work very well. The conversion of models to RSA for example, some steel profiles will not convert and nodes are not lined up etc. The connections made in Tekla will not convert, only bars with nodes. We have tried several times. It's faster to make you onw model in RSA.
