1 ) how Linking Robot Structural to Tekla Structures and vice versa ?
2 ) If I Export entire structure designed from Robot to Tekla, can I see entire structure Even with correct Steel Connections ?
Ask Tekla
in the name of GOD .
the content of these link isn't useful and very bad.
please help me more
How can I help you?
LInk from Robot to Xsteel is made by Tekla so please ask them.
I could not find anything about it. the page you've introduced nothing was useful.
please introduce for me a link for download robot ro tekla exporter or tekla to robot exporter.
very thanks
mpcloob
There is more chance GOD will create this link than anyone at Autodesk. Just letting you know.
By the way, Revit talks to Tekla.
Tony
Because Tekla did it.
Maybe CIS/2 format is acceptable by you.
this is unsufficient explanation.
please describe more about linking Robot to Tekla and vise versa. Robot to Tekla specially
please attach image or images about this.
thanks beforehand
To get sufficient explanation, you need to address people at TEKLA and not Autodesk because Robot is linked to Revit and vice versa through Autodesk but anything related to TEKLA was created by the TEKLA people.
At this point, you either ask them, or do your own inverstigation.
Regards.
this answer isn't useful unfortunately.
I want from all experts to attach a video or image for example that linked a small structure from Robot to Tekla specially.
thanks beforehand of all experts & product supports
I do not want to be rude but the question comes to my mind : Have you read the messages 2 6 9 in this thread ?
Hi all
I trying to send model from tekla to autodesk robot. when I update result back to tekla
In the Tekla display not accept profile
Pls help me for this problem
Thank all
The link is owned by Tekla. Please contact them for help. Perhaps you have to just define a profile of such name in Tekla.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
sir, i got the same problem in tekla when i try to get a profile that i changed in robot. profile not acepted. i want to know if you solve this problem.
if someone want the link structural to robot x64 please send me a mensage
for download Tekla x64 - Robot use this link :
http://www.mediafire.com/download/dinpm8e57vpksn6/TeklaStructures_x64_ROBOT_154_setup.zip
and for download Tekla x86 - Robot use this link :
http://www.mediafire.com/download/pcciltz7zoibyyy/TeklaStructures_ROBOT_154_setup.zip
and for download Tekla - SAP2000 14 use this link :
http://www.mediafire.com/download/n9ysddrdfcafcfb/TeklaStructures_SAP2000v14_152_setup.rar
That Robot - Tekla link works with robot 2015 and tekla 20?
Can someone send me Sap2000 v16 link to Tekla 20 too? Thanks a lot!
