Is possible link RSA with matlab instead of Visual Basic API. The idea is to use Matlab for optimize structures calculated in Robot. Matlab can calculate with Ansys but... with Robot, is possible please?
Thanks!!
I don't like to develop a software from excel because I want to calculate de joint and the efect of the semirigid joint in the frame in order to optimizate the structure. Are you sure is this posible? define the joints (diameters of bolts,. plates...etc), section of beams columns,, check the joint in RSA and columns all together in one step from VB?
Cheers
According to this article :
http://www.mathworks.com/help/matlab/examples/programming-with-com-on-windows.html?prodcode=ML
it should be possible to use Robot API (COM) from Matlab
Additional info of your concern posted here:
http://forums.autodesk.com/t5/robot-structural-analysis/api-control-of-robot-structural/td-p/5639590
