Linear Support on Panel Edges
LuisMCosta
LuisMCosta
Hello everybody,
I'm trying to define linear pinned supports (PS below) for a core wall but somehow I'm not finding a way to do it. Can you please tell me what can be the problem?
Thanks in advance
Rafacascudo
select the line with "edge(2)" on the dialog window and click OK
Rafael Medeiros
LuisMCosta
Rafacascudo, thanks for the answer.
Still nothing happens...
Rafacascudo
check if the supports viewing is on.
generate the model .
If still it doesn´t show up , send the model
Rafael Medeiros
LuisMCosta
Rafael,
Please find attached the model.
Thx again 🙂
Rafacascudo
Working normally here on both Robot 2017 and 2018 . Are you sure the "supports" viewing is turned on?? beacause they were OFF when I opened your file
Tem certeza que os apoios estão ajustados para aparecer? pq eles estavam desligados qdo abri seu arquivo!!
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @LuisMCosta
I just wanted to check if @Rafacascudo suggestion solved your issue Smiley Happy
Artur Kosakowski
