Linear releases panel
I want a releas between two panel when I release on both edges I get an instablity warning.
If i only put a release on one side the other side will have a moment, how do i solve this problem?
How does linear releases work?
EduardoMeruvia
Hi @Anonymous ,
Putting a linear release on ONE side only should be enough to avoid out of plane bending continuity on the slab.
Are you looking at out of plane bending or in-plane bending of the slab?
According to the picture when I use one release the other side wil have a moment how do i solve that?
And i want no bending in de slab is that possible?
Rafacascudo
If possible ,zip and send the model telling which panels have the problem
Rafael Medeiros
Every panels ; ). The panels/walls shouldn;t have moment, how do i achieve that?
Thx for your help
Rafacascudo
You must know that you cannot have to identical releases for all neighbor edges . At least one edge must be unreleased. See below an example.
Deleting all your linear releases and assigning a moment release to your bottom slab edges  , the results will show zero moments at the slab edges
Rafael Medeiros
