Can you tell me how can i define a linear release with this conditions:
Ux + release
Ux - release
Uy + release
Uy - release
Uz + release
Uz - fixed
Rx + release
Rx - release
Because i can't see the the way to put at the same direction + plus - , like i need per example in Ux.
Best Regards,
Ricardo
Solved by Artur.Kosakowski. Go to Solution.
Assuming that by releasing both - and + you mean that the release works in both directions it is enough to mark Ux, Ux and Rx check boxes on the linear tab of the dialog. The unidirectional is intended for either + or - (e.g. allows for uplift but works in the downward direction).
Right, but at unilateral tab, on the selection box i just have, blank, - way and + way.
Standing in blank means that is released at both ways?
Depends on what you marked on the linear tab. If you marked the check box then this d.o.f is released (both ways). If not this is the fixed connection. The unilateral tab is to be used only when you want to define the unilateral release (the check box on the linear tab will be unmarked).
Thanks Artur, i already understood.
I never thought that linear tab and unilateral tab were depent.
