Linear load not applied to a panel
I am unable to apply linear load to panel member.
While generating LM71 moving load over a floor plate of a bridge deck, only the axels are applied to panel members and NOT the linear UDL.
Could someone suggest how to solve this.
Mithra
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
Please find attached the file. Load case 4 is the moving load case.
Regards
Mithra
Rafal.Gaweda
Autodesk Support
Autodesk Support
Why do you think so?
Check sum of reactions in each moving load step.
Rafal Gaweda
After analysis, there was a warning message "Linear load not applied to a panel".
Added to that, I did not check the display option for moving load vehicle.
Thanks!
