- Mute
- Permalink
- Report
Hi all,
I am trying to run a linear buckling analysis on the attached model, and it is all working. What i want to do is release the 'wing' braces, that is the diagonal brace at each level, to have a pinned joint at the junction with the tower. This wing brace has a horizontal fixed, vertical free support at its other end (ie a vertical roller). As soon as I release the brace at the tower end the analysis will not run. I think I am correct in releasing Z and Y at the end of this member so that torsion remains fixed, but I can't get the analysis to complete. I think the fixed joint might be giving me slightly high results.
Can someone give me a pointer why it wont run?
Thanks, Ian.
