Latest Updates | New Knowledge Network Articles | Robot Structural Analysis
Azmeera.M
Alumni Alumni
Azmeera.M
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Robot Structural Analysis?
(List shown in chronological order)
 Subscribe to receive updates for new Robot Structural Analysis's Knowledge Network articles.
For more updated solutions, also check out the AutodeskHelp Blog!
Azmeera M.
Autodesk Employee
Azmeera.M
ARCHIVE
January - February 2016
How to define compatible nodes
How to define seismic or spectral cases
How to ignore some bars in a cladding load distribution
How to open file in repair mode
How Wind Load Simulation Works
Incorrect display of (exact) deformation diagram and corresponding values for more than one case
Lateral buckling: Critical moment differences between super member and its components (Robot)
RC Slab Provided Reinforcement - error: “For top or bottom reinforcement in the direction of X or Y
Structure verification-Warning message “Parameters of the material used in the object are different
March 2016
ROBOT - STEEL DESIGN - calculations dialog box is not correctly displayed
Strange patches or strips on maps
April 2016
ROBOT-Model editing-how to change the section color
Seismic analysis-How to create a seismic analysis with spectrum values different from the ones in th...
Get Up to Speed: Robot Structural Analysis 2017
May 2016
How to understand the thermal effects in a building including bars and panels.
Nodes defined along a cable are reported as isolated
June 2016
About instability types
Corrupted units in job preferences leading to obtain incoherent results
How to define a time history analysis and how to explore results
How to run model calculations with reduced stiffness of concrete columns and beams
JOB PREFERENCES - empty material lists
RC reinforcement bar database edition - it impossible to open database editor
Robot model definition: How to offset the support of the structure
Panel calculation model- one way simplified transfer of loads
July 2016
Error: ‘Members have not been calculated because they are composed of sections not available in the ...
Error: “rohtml.dll not found” during attempt to calculate steel connection
How to apply soil elasticity on a raft created as a panel
How to create a moving load in Autodesk Robot Structural Analysis Professional
How to clear out recently used projects in Robot
Robot - RC SLAB REQUIRED REINFORCEMENT - How to include creep and shrinkage in calculations of defle...
How to set hydrostatic pressure load on model
August 2016
Climatic loads-EC1-Error message “Algorithm of structure geometry identification has found out that ...
Multiple nodes numbered « 0 » (zero) displayed in the nodes table
Non-convergence of a model with unidirectional supports or soil (uplift allowed)
RC SLAB PROVIDED REINFORCEMENT - can definition of zones be saved as dwg or dxf file
RC SLAB REQUIRED REINFORCEMENT - how punching reinforcement is calculated?
Results analysis-Sign convention for bar elements
ROBOT - CODE (AUTOMATIC) COMBINATIONS - some load cases not included in list of generated combinatio...
ROBOT - Load to mass conversion - conversion of combination is disregarded
ROBOT - RC COLUMN DESIGN - impossible to change status from red ? (question mark) to OK
RZ instability of type 3 reported during calculations of frame mode or regular building with pinned ...
SEISMIC ANALYSIS - how to scale base shear in seismic load
Seismic analysis for nonlinear model
September 2016
Bar element displayed as a blue dotted line
Buckling Analysis-find Alpha-cr for structural analysis according EN1993-1-1
How do I model a structure with 10% base fixity?
How to activate seismic provisions in the provided reinforcement modules
How to create a nodal elastic support
How to determine base shear under seismic actions
How to switch off use of kinematic constrains
RC DRAWINGS - no bar diameter on drawing
ROBOT and Advance Steel Interoperability
ROBOT-Steel design-How to run a fire analysis for Eurocode 3 based codes
Steel Design - no buckling check
Steel Design - which of available design codes support thin walled section verification
October - November 2016
Automatic wind loads determination – NF EN 1991-1-4 – Does ARSA considers clause 4.4(1) NOTE 2 of Fr...
Concrete design – How to update concrete elements dimension in the model based on the optimized sect...
Error “Distorted element”
For code combinations according NF/BS/PN EN 1990, live loads category H are combined with snow / win...
How to delete already defined loads
How to determine the dynamic effects of pedestrians walking on a footbridges according the French SE...
How to download Robot to Advance Steel 2016 link?
How to obtain shear forces acting at the bottom of a wall.
Modal analysis - warning:‘Number of missing eigenvalues found’
Modeling – How to define an opening in a cladding or a panel
No convergence during non-linear analysis on a model with uplift definition of supports
Not possible to change row height in all tables
Panels \ walls not displayed in Object Inspector
Printout composition – screen captures of the structure view are black
RC BEAM - How to design (T shape) beam defined under slab
RC plate and shell required reinforcement – Openings not considered during required reinforcement de...
RC SLAB REQUIRED REINFORCEMENT - error: “required types are not ascribed to SLS combinations. Calcul...
Registering, reregistering, running two or more different RSA versions on the same computer
Required reinforcement for plate and shell-Reduction of forces above supports
 ROBOT - STEEL DESIGN  – warning message: “Angle is not checked for buckling to the weaker axis of t...
ROBOT - STEEL DESIGN - NBN EN - incorrect use of method 2 for stability check
Warning: “Isolated nodes have been found” reported for nodes that don’t exist in a model
What stiffness matrix is used for modal analysis for nonlinear model
Azmeera M.
Autodesk Employee
