Lateral Earth Pressure
Sally_Ameen
Sally_Ameen
Hi Everyone,
I am trying to model lateral earth pressure from a user defined soil (Phi 23 degree, Density 1800). But, when I apply the load the pressure will become double on my model.
with hand calculation I expect 31.7 KN/m2 but robot shows 63.41 (exactly double amount!!).
Attached is my model and appreciate your support to let me know if I modeled anything incorrectly.
Thank you in advance..
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Sally_Ameen
This value describes contour load in one of 3 points determined for defined geometry and soil layers.
In that case value corresponds to pressure on level in point C  (z=-4.1 m)
Since model height is 4.1 applied load should be correct.
Krzysztof Wasik
Sally_Ameen
Thank you Krzysztof. As a resultant point load I expect  ~ 63.41  KN per meter run ( 0.5 x lateral soil pressure x structure height = 0.5x31.7x4.1) but robot calculates 63.41 KN/m2 which translates to resultant point load of 0.5*63.41*4.1=129.97 KN per meter run
Sally_Ameen
This my hand calculation
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Sally_Ameen
Results are correct. In contour load definition pressure 65 applied on level -4.1 correspond to pressure 32 applied at level 0
While pressure load application program describes pressure below wall bottom level.
In your case total horizontal reaction is 65 kN as expected.
Krzysztof Wasik
Sally_Ameen
Thank you so much it is clear now. But, honestly it is over complicated 😁 why the "soil pressure model" generates a load at Z=-4.1 while my structure height is in the positive Z direction.
Is there any way to avoid generating earth pressure at negative Z direction?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Sally_Ameen
No. You cannot modify this automatic procedure. You can correct generated load manually (as on screenshots from my previous emai) to obtain required load description. Regardless that load is applied to the structure correctly.
Krzysztof Wasik
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
