When i run the design, the program throw "The program has not performed the lateral buckling verification" i assign the the lateral buckling at code parameters and the message of error is the same
I define the design parameters corresponding at member, and still continue the error
after running the structure calculations and choosing the ANSI/AISC 360-16 code, here are the results I get
you also need to make sure that all storeys are defined and that columns are interrupted at each floor level
After cuts, to justify the different trunks, you need to create superbars
Best Regards
