Kz elastic foundation coefficient - what it really means?
sweapon
Message 1 of 14
sweapon
Hi Everyone,
I'm trying some examples with RSA (just practicing) on trying to design some foundations, but i have a question, what does it really mean the Kz (elastic coefficient of the soil) and how its calculated, I suppose it must be dependant of the Friction angle and the cohesion, but i cannot find any relation, i have tried looking on the web for any information on this but couldnt find anything, hope anyone can help.
Alex
Replies (13)
Message 2 of 14
Hi Sweapon, check this thread.
http://forums.autodesk.com/t5/robot-structural-analysis/elasticity-coeff-slab-design/m-p/5801173/hig...
You can find more information in these books:
-Soil Mechanics in Engineering Practice: Karl Terzaghi
-Foundation Analysis and Design: Joseph E. Bowles
Message 3 of 14
sweapon
I checked some books and robot help material, found it in most books as "Ks" elastic reaction, i hate when this happens some time, when variables change between different books.
Cheers
Message 4 of 14
Hi
The Kz (Uz) coefficient is stated as units (kPa) as in kN/m^2....how does this directly relate to the ks factor given as force/m^3?
Is this exactly the same factor? If so, why isn't the kz units shown accordingly?
Message 5 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
The units depend on the type of the foundation. Could you attach the screen capture so that it is clear what exactly your question relates to please?
Artur Kosakowski
Message 6 of 14
Message 7 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
This is for unit length of a bar considering it width so kN/m3 * 1 m = kN/m2
Artur Kosakowski
Message 8 of 14
so for example, if my site corresponded to a value within this table;
ks (kN/m^3) x 1m = kz (Uz) (kPa)?
Message 9 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
In terms of a bar (e.g. 0.3 m wide ground beam) you should also consider its width so for 1 m length it will be:
KZ (kN/m2) = ks* 0.3 (width)
Artur Kosakowski
Message 10 of 14
sweapon
Thanks Artur, for lighten up us all, i have seen most of your videos on youtube which i find very good for the higher experinced in robot
Message 11 of 14
Sorry Arthur,
I know that maybe the post is old, but I just in this problematic at moment, and because I'm in Spain at moment, I had Geotechnical report showing some K30 value called BALLAST COEFFICIENT. Is this same coefficient that I need in Robot called Kz??
Usually I'm calculating this value automatically with the procedure in Robot, but in this case I need to use those values specified in the Report.
Thnaks,
Carlo
Message 12 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
looking at page 245 from
https://books.google.pl/books?id=ygKio-Ks0doC&pg=PA245&lpg=PA245&dq=BALLAST+COEFFICIENT&source=bl&ots=AJ8-nDxgyk&sig=ACfU3U0JspS2lhHcodezcrg_PC3ZtuDTBQ&hl=pl&sa=X&ved=2ahUKEwjA-KXb8N7gAhW7RhUIHfZPC20Q6AEwCHoECAQQAQ
it is the same.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 13 of 14
Thanks.
Message 14 of 14
memoalcr
Just to be clear, and I am not a geotechnical engr. is the "elastic foundation coefficient" Kz used in Robot the same as the "modulus of subgrade reaction" ks? or do I have to transform ks into Kz? How do you do the conversion?
