Is there any way to assign keyboard shortcut keys for the view cube home button? Moreover, is there any way to assign keyboard shortcut key for right click => select & right click => cancel.
I realize that these are the most used clicks I use the mouse for and was wondering if there is any quick way to bring these shortcuts on my keyboard.
Thank You in Advance.
Solved by Rafacascudo. Go to Solution.
Ctrl+ALT+0 for home button
for get back to selecting mode just click ESC
You can customize shortcuts on Tools/Customize/Customize keyboard
Rafael Medeiros
Accepted as answer.
ESC completely deselects everything. I was looking for a shortcut key especially for "right click=> Select".
I know this customization process and I have assigned all the required commands as per this customization.
But I could not find where I can assign "right click=> select & right click=> cancel" shortcut.
