IT CAN BE AVOIDED THE PUNCHING DESIGN IN SLAB REINFORCEMENT ???
StefanoPasquini6790
Advisor Advisor
StefanoPasquini6790
Hi everyone,
I've modeled a composite steel-concrete bridge. To create the connection between the slab and the beams (stud) I used a round steel bars. When I run the design of the reinforcement concrete of the slab, there are a lot of reinforcement used only for punching, but the punching is not really present in the slab. It exist a way to avoid the punching calculation in Robot??
I could change the studs in to Rlink, but I'd like to know if there is another way.....
Thanks in advance for your usual kindness.
Cheers
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Stefano,
Try to define 1 mm size beams at the locations of the studs as punching is not checked over beams.
Artur Kosakowski
StefanoPasquini6790
Thank you my dear, I will try this trick!!
Cheers and have a nice weekend.
PasProStudio
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Stefano,
Let me know if this worked for you Smiley Happy
Good luck with your new project.
Artur Kosakowski
