Isolated support noted on solid elemet
Hi
I'm having a problem with my model. I'm trying to model a concrete block that is being lifted in 8 hooks as i moddeled as pin-supports. My problem is that the auto-meshing dosent include my support and just says isolated notes. I've tried to do it over a couple of times but with the same result...
I've attached my model, if that helps, othervise I hope you can tell me what I am doing wrong??
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal.Gaweda
Autodesk Support
Autodesk Support
In your model, after meshing, run Edit \ Correct (Entire structure) to merge nodes
Rafal Gaweda
