Isolated node error
Isolated node error
Isolated node error
I am having trouble with an error in a model when I verify or run the analysis; there is an isolated node however the isolated node has coordinates -nan(ind) and I am unable to find/delete the node.  I have also opened the file in repair mode but this hasn't resolved the problem.
Also when I run the full analysis, columns around the area with the problem are suddenly deleted without me deleting them.
Is there a way to fix this error? I have attached the model to this post.
Many thanks.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
This node can be deleted from Nodes table.
I would suggest to turn off "Kinematic constraints in incoherent points" in Job Preferences \ Meshing and mesh model again.
Rafal Gaweda
