Is this correct way to get a fixed-fixed connection?
cagosi4788
Message 1 of 8
cagosi4788
I have two big plates, and inbetween there is a smaller plate connecting the two bigger plates. I want the small plate to be fixed to both sides, and was wondering if I have done it correctly as seen in the attached picture?
I ask because I am working on a model someone else made, and their definition of fixed does not match what I think fixed end should be (displacement and rotations fully restricted).
Replies (7)
Message 2 of 8
Rafacascudo
Completely wrong. That full released bar on both ends will give you lots of instabilities warnings and results will be wrong.
Model the small plate also as a panel or at least as a non released bar with full rigid links from bar end nodes to big plate nodes within bar width
Rafael Medeiros
Message 3 of 8
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @cagosi4788
Release defined in your model has all defress of freedom free.
In your case small plate is simulated by beam. Remove release from beam (default beam /slab connection is fixed, no need for release definition).
To avoid stress concentration in slab/beam connection point I would recommend to connect each beam endnode with neighbouring slab nodes using rigid links. It will transfer force from beam to slab edge segment corresponding to beam width
Krzysztof Wasik
Message 4 of 8
cagosi4788
Thank you for the reply Krystof; have I fixed the beam to be fixed-fixed now?
In reality the bar is supposed to be a small plate that has been bolted underneath the two plates. Its supposed to prevent horizontal movement of the two bigger plates. I am not sure if it needs to be fixed-fixed, or fixed-pinned?
Message 5 of 8
cagosi4788
I seem to have misread how the connection works . You seem knowledgeable at this topic, if I may also ask; In reality the bar is supposed to be a small plate that has been bolted underneath the two plates. Its supposed to prevent horizontal movement of the two bigger plates. I am not sure if it needs to be fixed-fixed, fixed-pinned or some other type of connection?
Message 6 of 8
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @cagosi4788
If small plate is supposed to prevent horizontal movement I would use pinned pinned connection (in vertical plane). Small plate will not transfer significant bending moment if it is bolted like on the picture
Krzysztof Wasik
Message 7 of 8
cagosi4788
Do you think there might be some instability issues if we dont fix one side? And if it is expected to carry some moment, do you think fixed-fixed or fixed-pinned could be a good idea? Would be hard to know which side to pin though...
Message 8 of 8
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @cagosi4788
I see only model part with mo supports and other connected members. I cannot sayif releases will cause instabilities. You can just run calculation and check with different releases setting.
Krzysztof Wasik
