- Mute
- Permalink
- Report
Newbie here. I'm looking to model a one-way slab in robot.
The slab spans 3.5m, with line supports at 0m and 3.5m.
Between 0m and 0.5m I want a depth of 0.15m. Between 0.5m and 3m I want a depth of .25m. And between 3m and 3.5m I want a depth of 0.15m again. The top of all three panels should be flush. Poory drawn diagram attached.
I have tried to model this by drawing 3 rectangles in top view, and turning them into panels of different depths. I quickly discovered that to get the panels flush at the top I would need to draw the central section slightly lower than the two at the edge.
Once I had all 3 panels flush on top I put the line supports in. When I hit go however, the middle part of the span just dropped out, and then 2 at the edge just folded in on the linear pin supports. I got lots of error messages.
How do I join the panels up so that this doesn't happen?
Or am I going about modelling my slab in completely the wrong way? If so, what other ways are there to model my slab?
Many thanks,
Will
