Is it possible to pre-tension the cables? I am unsure how to pre-tension the cables, they are not resisting the loads. It is for set 14 (COMB3).
Thankyou, however from this a 'No convergence of nonlinear problem' rose once calculated. Do you know how to fix this please? Maybe my model is unsatisfactory.
Hi 6c2,
normally with cable structures you have to:
1) fix rotations for all nodes where cables are linked to each other
2) instead of apply a force in the cable for pretension load it is better apply load by means of epsilon (eps=N/EA)
3) use Full Newton Raphson method for all loads and comb.
Bye
Roberto
