Is it possible to convert automatically generated loads?
Message 1 of 10
If I go to View -> Display -> Loads, I can check "Forces generated automatically" and see these loads. Is it possible to convert them to a new load case?
Replies (9)
Message 2 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
I am afraid not.
You have to write API macro or copy them to Excell , adjust records.....copy back to Loads table
Rafal Gaweda
Message 3 of 10
How do I copy them to Excel? I can't figure that out.
Message 4 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 5 of 10
I know how to copy data from a table, I just do not know where to find the table with the generated forces.
Sorry for not being more precise.
Message 6 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 7 of 10
Good day Rafal,
Regarding the results obtained from ticking the box as shown above, is there a reason why the trapezoidal load bar number are not given, or am I missing something else?
Hendre
Message 8 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dear @Anonymous
Some load types displayed using mentioned checkbox are in fact kind of internal load types, not available for user, so some data may be missing in table.
For example loads from claddings can be generated as 11 point trapezoidal bar load which does not exist in interface.
Rafal Gaweda
Message 9 of 10
Hi Rafal,
Thank you for the reply.
Is there a way then that this information can be exported in some way? I want to obtain the automatically generated line loads on the beams to a format that can be converted to Patran Syntax as it is quite a challenge to convert the Robot panel loads to Patran Syntax.
Thank you
Message 10 of 10
Romanich
Hi @Anonymous,
Have you tried this small but very powerful program?
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-addin-for-coping-loads-for-load-c...
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
