interpreting alpha_cr values EC3
Mohamed_AbdElAziz4TPC2
hi everyone,
I am getting very low alpha_cr values  of 0.2 under own weight case 1
then zero or N/A under vertical dead and live load cases
then very high values under various combinations
1.can someone help interpret it ? and should I get it for load cases or combinations?
2.is buckling analysis necessary to get correct values ?
I attached model and screenshot
thank you for your time
Simau
@Mohamed_AbdElAziz4TPC2
Except for the selfweight, it is not necessary to calculate alpha cr for simple cases, but only for combinations.
The interpretation of alpha cr must be done in parallel with the deformation of the structure. The alpha cr that must be looked at is the one whose mode deformation corresponds to a global buckling.
Avoid separate structures, because the Alpha cr coef found will be applied to the loads of the buckling structure, therefore not easy to manage with several structures on the same model
Example: screenshot for combination 102
M. Agayr
thanks @Simau I appreciate it
