Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Integration with Advanced Steel - ERROR
13 REPLIES 13
Message 1 of 14
juan.castilloQTESQ
997 Views, 13 Replies
I am having an error while transfering my model to advaced steel for connection design, and cant find any solution for it.
13 REPLIES 13
Message 2 of 14
Hi @juan.castilloQTESQ
Could you please share Robot file for verification?
Krzysztof Wasik
Message 3 of 14
Sure, attached file, @Krzysztof_Wasik hope you can give solution to this soon.
Thanks.
Message 4 of 14
I have managed to save SMLX file in Robot 2021 with Advance Steel link 2021. SMLX can be read in Advance Steel 2019
I get the same issue as you exporting file in 2019 and 2020.
I am sending SMLX file and AS 2019 model,
Please let me know if it will help
Krzysztof Wasik
Message 5 of 14
Yes, @Krzysztof_Wasik it opened the smlx file perfectly with results, by the way my Autodesk Collection is 2019 all of them (Revit, Robot & Advance - so i shouldn't have any problem in my workflow) why am i having this issue and will i keep getting it every time i export robot to advance... *Note: earlier this year i've exported a project (robot to advance) and i didn't get this error before!
Thanks for the help!
Message 6 of 14
It seems to be issue with Advance Steel link 2019 and 2020,
Maybe Robot updates  are in conflict with Addin.
The strange thing is that when I send results for single load cases one by one it is OK . While sending results for 5 load cases together I have this issue.
While sending model with no results everything is OK
I will ask my colleagues about that but it seems as issue for investigating by developers.
Krzysztof Wasik
Message 7 of 14
Ok, good to know, and if there's an update regardin this error, please let me know.
Thanks, @Krzysztof_Wasik Have a nice day.
Message 8 of 14
Good day @Krzysztof_Wasik, how do you send only 1 load case from robot to advance? since client made changes i need to redesign my connections! I'm still havign this issue of exporting to advance with results 😞 (no problem exporting only model).
Thanks in advance
Message 9 of 14
hI @juan.castilloQTESQ
I have managed to export model with one load case when I have removed the other load cases from Robot model.
Actually I have no good solution for that issue except of using Robot 2021 with Advance link 2021.
If you need model transfer and you cannot use 2021 I can do it for you.
Krzysztof Wasik
Message 10 of 14
i've attached model for exporting,
thanks
Message 11 of 14
@juan.castilloQTESQ
Modified file saved as SMLX and DWG attached
Krzysztof Wasik
Message 12 of 14
@Krzysztof_Wasik hello, once more i need your help transferings a model to design connections (i need combination results), i'm still having the same integration problem Robot 19' -> Advance 19', i'm sending file.
Any solution from developers to this problem with the addin??!
Thanks in advance!
Message 13 of 14
Please find attached SMLX file. I do not have any information about Robot-AS 2019 link update.
Krzysztof Wasik
Message 14 of 14
in reply to: juan.castilloQTESQ
Hello guys, I'm also having the same problem with the integration. What could be the problem? Kindly assist.
Technology Administrators
