Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Instability type 3 - arch truss structure
5 REPLIES 5
mathias_peron
652 Views, 5 Replies
Hi everyone,
It has been few time that I restart my model paying more and more attention when I apply the releases to the structure but I still get a type 3 instability.
I verified the displacement and all seem ok. And if really everything is ok, why the software keep warning me? What should I rectify?
Have a nice day,
Mathias.
5 REPLIES 5
Artur Kosakowski
Thank you it resolved my problem but I don't understand what happened. Could you explain me what it changed?
Thank you.
Blocking RX at both ends prevents rotation of bars about their own axes due to releases applied to other bars defined at their end nodes. You may check values of Mx and apply them in only in the locations where you find torsion excessive.
Artur Kosakowski
I made the modification for all my releases, is it not correct then?
You need to judge this by obtained results,. Usually connections are created in such a way that they doesn't allow for rotation along own axes of bars so you should be fine but as I wrote you may just have a look at Mx values. You may also decide on partial releses for Rx at both ends of bars - see:
http://forums.autodesk.com/t5/robot-structural-analysis/instability-pinned-bar-truss-bar/m-p/5810980
Artur Kosakowski
