Hello, I have about two years of experience with Robot Structural analysis. I have successfully used the program several times to determine the best sections for the job.
This time however I am getting frustrated with error messages everywhere and am not able to figure out how to stiffen the building with steel shell, nor why the roof truss does not want to cooperate.
This is a building that I have been tasked with expanding the existing area to make room for concrete hollow slab storage area. And determine the load that is to be transferred to the foundation.
I have been struggling with this for several days now, alone. And I just want some input from more experienced users that could point me in a logical direction.
First I tried to make panels in building design to add to the roof and walls, to act stabilising. I used the given model to determine the shape of the trapezoidal plate with 1mm thickness. Then I added them to the roof and walls, and set them to be calculated as shells. This gave me error instability type 3 in different nodes each time. Then I researched meshing, got it perfect, still instability. I tried to calculate them differently, as walls, shells, with concrete reinforcement as walls and floors still got several error codes.
Then I ignored the errors and tried to calculate nevertheless, I found that the steel roof trusses were unstable and gave me a ratio of 200000 or more. I then gave up entirely and decided to model the original building alone, with only claddings and fixed supports, as the concrete foundation more or less gives it approximately a fixed situation. Still the roof is unstable. I am expecting to be able to add 4kN/m^2 snow load, but it is unstable without anything.
I am at a loss here, if anyone could help and give the model a look I'd be very much appreciative.
Mind you the building is actually supposed to handle this as it is modeled, it is already buildt and standing proud. Also the bar force is a moving crane of 10kN
Using windows 10, robot 2019.
