instability problem in rectangular steel tank design
EnricoCorvaglia
EnricoCorvaglia
Hello to all
Do any of you have expirience about design of an open rectangular steel tank?
I modeled a rectangular tank and designed according to Eurocode 3 and the aisc, in both cases I have a problem of instability as outlined in the attached figure.
I tried to reinforce and use different shapes (even closed shapes) but the problem persists.
Can someone help you solve it?
thank you
italo
EnricoCorvaglia
Hello to all
thank you
Italo
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EnricoCorvaglia
If the steel profiles are welded to the tank plates shall their unrestrained buckling length be 7.5 m?
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
