Instability of Nodes on pinned-pinned members
PaulGrimes2282
PaulGrimes2282
I have a model where i have one final instability that i cannot figure out - a node sits on a pinned-pinned member (Ry, Rz release one end, Ry Rx the other) and it says that it has an insability in Ry direction (which i think is Ry global? - i.e. Rx in the member axes).
I have attached a screenshot, and the model - would someone be able to explain to me why the node is still unstable?
thanks!
Rafal.Gaweda
Autodesk Support
Autodesk Support
PaulGrimes2282
That looks like a really useful plugin - thank you i will have a look at it.
So the instability isn't actually anything to do with the node it is saying - it is just a result of the way that the matrix is set up? Is this the case for any type 3 instability? Sorry just trying to understand so that i can correct my own models in the future!
Rafal.Gaweda
Autodesk Support
Autodesk Support
In case of instability type 3 it may not point directly to node with so called "problem".
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/instability-type-3-RX-direction/m-p/3364875/...
In such case you should look for short elements in your model first.
Rafal Gaweda
PaulGrimes2282
thanks - will do!
