Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Instabilities type 1, 2 and 3
12 REPLIES 12
Message 1 of 13
1017 Views, 12 Replies
I made a column as a truss and got lot of errors. No idea what else can I change. I added only self-weight and even though there are 10000m displacements.Instability 1.jpgInstability 2 UZ.jpgInstability 2.jpgInstability 3.jpg
12 REPLIES 12
Message 2 of 13
1234eddie
@Anonymous
Can you show the Bar End releases?
Gr edward
Message 3 of 13
Simau
Hi @Anonymous
Try to set the 4 column as "simple bar", not truss
M. Agayr
Message 4 of 13
in reply to: 1234eddie
Sorry for german menu. Gelenke = releases. I tried also to make all the bars pinned-pinned
Message 5 of 13
in reply to: Simau
@Simaudidn't work
Message 6 of 13
Simau
Can you attach your model?
M. Agayr
Message 7 of 13
in reply to: Simau
Sorry, that .zip but .rtd somehow doesn't want to be attached
Message 8 of 13
napooil
Message 9 of 13
Simau
@Anonymous
You have some weird excenticities, i deleted them
I added  horizontal bars to close the truss
Model attached
M. Agayr
Message 10 of 13
in reply to: napooil
@napooil   Ok, it works, however I'm not sure if I attached windload properly.
Nevertheless what is the point of designing 3D truss when at the end you need to change it into a 3D frame?
Do I have to set all the bars as pinned-pinned or pinned-fixed or can I leave it as a fixed-fixed?
@Simau  I can't see them. How can I delete them?
Message 11 of 13
Simau
Select all the structure then
M. Agayr
Message 12 of 13
in reply to: Simau
@Simau  vertical displacements are gone (UZ). UX still there.
Can someone explain why after converting into frame my construction works?  Do I have to change then all the bars as pinned-pinned?
Message 13 of 13
Rafacascudo
Your original model cannot be qualified as a 3d truss . In this "geometry type" all bars are automatically treated as truss bars. So , all nodes/joints are pinned which makes some of your nodes unstable.
So , that´s why it will only work only if it is treated as 3d frame .On Those unstable nodes above , Shear on the vertical chords would make the structure stable.
Rafael Medeiros
