Instabilité se type 2
kirilascar
Message 1 of 15
kirilascar
Bonsoir,
je modélise un bât R+3 de CBS vers Robot structural analysis RSA! après générer le model de calcul puis vérifier la structure nous avons 0 erreur et 0 avertissement !! Puis dans l' onglet analyse puis calcul, nous avons des instabilités de type 2 aux noeuds 1506 vers RY .
Comment on résolu cette  solution .
Ci- joint le fichier et la capture d' écran .
Cordialement .
Replies (14)
Message 2 of 15
Rafacascudo
Certainly too many releases
Watch webinar 16 about instabilities on Build your Robot Structural Analysis IQ - YouTube
Rafael Medeiros
Message 3 of 15
kirilascar
Good evening
a big thank-you ! But this link I already in french! I put a lot of time on the linear releases I'm really blocked!
Message 4 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @kirilascar
Try to redefine the linear release for UZ like that
Artur Kosakowski
Message 5 of 15
kirilascar
Hello,Good evening Mr .
I redefined your screenshot as shown above! But a Type 2 instability type error message !   Always instability errors of type 2 !
THANK YOU FOR YOUR HELP !
Message 6 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @kirilascar
Indeed I overlooked the actual reason which was rightly suggested by @Rafacascudo. The only thing which I may use as the excuse is that I wasn't expected definition of the releases for cantilevers Smiley Wink
Please remove all linear releases from the panels below and keep the releases as originally defined.
Artur Kosakowski
Message 7 of 15
kirilascar
hi Mr Arthur ,
If I understand you it is necessary to go in the menu structure then additional characteristics then again releases linear and then uncheck all linear releases.
In CBS pro free XY we double click and we go in lineaire then we uncheck Ux Uy Uz and so from the same CBS pro free Z and CBS pro rel .
Here is the screenshot below:
Message 8 of 15
kirilascar
hi Good evening teacher ,
If that 's not what your procedure is in the form of screenshot.
Thank you Best regards
Message 9 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @kirilascar
You can remove linear releases from all edges of a panel in this way:
Artur Kosakowski
Message 10 of 15
kirilascar
Hi, Arthur
Thanks for the precise information! I saw the final result is very well done! But I did not quite understand what you can take an example that is to say the panel 324 to do it step by step with screenshot. I do not want this kind of problem again....Smiley Happy
thank you !
Message 11 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @kirilascar
I'm not sure if  I understand what you asked for correctly as I posted the screen captures in my previous post. Just type panel number (e.g. 3245) in the edge selection field, select X delete label and press Apply.
Artur Kosakowski
Message 12 of 15
kirilascar
Good evening,
Mr. After doing all this, there are always errors of instabilities! What the problem is, and yet I have removed all possible releases.
Thank you for your efforts!
Message 13 of 15
Rafacascudo
Your model has no problems at all if all releases(bar and panels ) are removed.
to delete all releases with no doubts do this below
and click on aplly button
Rafael Medeiros
Message 14 of 15
kirilascar
hi,
I won't ever be able to thank you enough for your support, which came via your messages.
Type 2 instability is solved now .
Thank you rafacascudo !
Message 15 of 15
kirilascar
hi ,
We can never thank you enough for your commitment.
Thank you Mr Arthur ! I can not thank you enough for making our house searching Process positively pleasurable !
I am a beginner on robot but how you knew to detect these panels.
