Hello
I would like to inspect the moment at a specific point with different mesh sizes; is there any tool in RSA to do that probe ?
Solved by Rafacascudo. Go to Solution.
create a node in the spot you need on the not meshed(empty) panel . Then any mesh size you set will make your node be part of the mesh.
Rafael Medeiros
