Incorrect displacements
Message 1 of 13
Hi, I am modelling a simple frame. What I cannot understand are displacements of 5 bars hanging from the main beam from the 4th load case "V1". It gives me over 34 meters of node displacement. Can somebody help me?
Replies (12)
Message 2 of 13
Simau
@Anonymous
Not easy to answer with screenshots only.
Share your model (zip it before)
M. Agayr
Message 3 of 13
Mohammed_Ata
Surely, there is a missed step. Upload your file for check
Message 4 of 13
Rafacascudo
you probably ignored an instability warning?
Rafael Medeiros
Message 5 of 13
There are no warnings during the calculations.
Message 6 of 13
I attached the file.
Message 7 of 13
Simau
@Anonymous
Didn't see any problem in your model.
Yes indeed weird displacememnts for nodes 6 13 14 15 16 under case 4.
M. Agayr
Message 8 of 13
Stephane.kapetanovic
your beam has no torsional inertia. Use a truss or create a compound section.
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 9 of 13
Torsional inertia is almost identical with given on a data sheet.
Message 10 of 13
Simau
There is no instability reported
So what is weird is that the displacement is 10 times greater than the length of the bar if it was horizontal
M. Agayr
Message 11 of 13
So I can assume that this is some kind of Robot error? I will try to model this structure again so we can be sure that this is a problem caused by the software.
Message 12 of 13
Mohammed_Ata
What type of sections used! I think the section are wrongly defined
I tried to change the section to concrete 450*450 and the displacement seems to be reasonable! (see the pic)
Please check your sections!
Mohammed Ata
Structural Design Engineer
Autodesk Expert Elite
Message 13 of 13
You have chosen a compound section and its calculation only adds the torsional inertias of each member instead of creating a complete section having an inertia as tubular
