Incorrect data of simplified code combinations
Mohamed_AbdElAziz4TPC2
Message 1 of 8
hello everyone merry christmass
I’m getting an error while generating simplified automatic combinations it says “Incorrect data of simplified code combinations”
I attached the model and snapshot
thanks in advance
Replies (7)
Message 2 of 8
Simau
Hi @Mohamed_AbdElAziz4TPC2
Maybe we don't have the same model. I got the following warnings
Model runs smoothly when changing Calculation modele GRT
Keep in mind, you have too much live load which will generate a huge number  of combinations and calculation time (with "or" operator).
M. Agayr
Message 3 of 8
Thanks @Simau for your help
it seems you  are using robot 2025 when i used 2025 i got the same warnings you get
i will try adjusting calculation model and get back to you
Message 4 of 8
i Tried GRT with the same settings as you did and the all warnings are gone except parameters of material are different
and it didn't produce the "incorrect data of simplified code combinations" error however it didn't generate any combinations
and the combinations drop menu doesn't respond to clicking
I changed the regulation file to EQ 6.1 now the "incorrect data of simplified code combinations" error is back again
and no combinations are generated
I attached the model saved with robot 2025
and 2 snapshots for the error and combination drop down menu
thanks for your effort
Message 5 of 8
Simau
Material warning is not critical, just change it to the same as other members
For combinations change code to NF EN as in the screenshot
As i said in my previous message, try to optimize the number of load cases
M. Agayr
Message 6 of 8
thanks for your response @Simau
i adjusted material as advised and the warning is gone
also used NFEN 1990 regulations but still get the same error and no combinations are generated
as for the notional load case they represent equivalent horizontal forces in euro-code 1993 and they cannot be applied simulatenously
unfortunately, that's why i am using simplified automatic combinations to avoid having thousands of combinations
Message 7 of 8
Simau
I used "manual combination generated" and didn't get any warning.
M. Agayr
Message 8 of 8
Hello @Simau
thanks for your response and sorry for my late answer
the issue with manual combinations generate is that it generates more than a thousand combination it  will be impossible to maintain and check
that is why i need the simplified combinations
