- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good morning Support,
I am designing designing piled slab that supports column and few liftshafts. I choosen to go with the shell model.
Above piles and in the location of the columns I created the rigid links to allow for the reansfer of forces through out the whol perimeter of each member.
When I am running the results, the results table for panels and shells give me in one critica combination value of around 460 kN but when I am looking at the map on the screen it gives me mximum values of around 550kN.
Could you please help as I don't know what is wrong and I am sceptic of what results I should do to undertake the reinforcement analysis.
Is it a problem with mesh?
My model is build from to seperate panels but when meshed it looks like the notes between both connect nicely.
Looking forward to hear from you.
Attaching model for reference.
Thank you
Jan
