INCOHERENT MESH ON EDGES
i set recommended meshing options according to autodesk wibbinar, but i still get error of INCOHERENT MESH ON EDGES
screencast:
http://autode.sk/2lRhu2w
*attached file.
Romanich
Hi @Anonymous,
Was the model exported from Revit?
Please check the second post on this topic:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-stops-responding/td-p/7661776
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
yes the model sent from revit to robot.
how to fix it in robot?
Rafacascudo
Hi @Anonymous ,
I had a look at your model  and all problems are due to small geometrical imprecisions . Always be aware when there are large concentration of nodes very close to each other.
Also many FE acute triangles like below
When you look closer you can spot the imprecision
And those above are not causing incoherent mesh error.
Also , I always prefer to mesh large models in stages. After correcting the model Try meshing the slabs 1st , freeze the mesh and then mesh the walls and freeze the mesh.
Always freeze the mesh if it seems OK!!.
Always use at least 4 or 5 decimals for coordinates/dimensions(job preferences/units) . Many times you can only check differences with 8,9 decimals!!
Rafael Medeiros
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
The way to correct inaccurate model coming from Revit:
Corrected model attached.
Rafal Gaweda
Rafacascudo
Hi @Rafal.Gaweda
How would you correct it in Revit??
Level by level or can it be done in a single step as in detailed correct?
Rafael Medeiros
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Rafacascudo
In Revit, there should be grid lines defined in correct analytical wall planes and then
or walls should be correctly created from scratch
See also video on slide 32 in webinar 10
Rafal Gaweda
